Let's see your breadboards!
Started by teej212, May 03, 2012, 09:19:53 AM
teej212
I've got nothing that i'm breadboarding at the moment, but I'm always curious to see what others are up to!
puretube
Currently got 2 on the bench:
+ some stored...  :icon_biggrin:
puretube
Quote from: puretube on May 08, 2012, 09:26:01 AM
sorry for the delay, but after the upload-issues have been solved,
here are the details... :
(23 breadboardz in total, if I counted right...)
Greenmachine
What you really need is some more stored breadboards.
Thomeeque
If you value your time and ideas then definitely..
Do you have a technical question? Please don't send private messages, use the FORUM!
Greenmachine
Quote from: Greenmachine on June 13, 2012, 12:33:08 PM
Hope this didn't come off bad ... was meant to be a joke.    :)
michelterres
ZW44 - Zakk Wylde overdrive, being tested and modified
puretube
Quote from: Greenmachine on June 13, 2012, 08:35:36 PM
You`s right -  some new ones came in today... :
so now I can poke in those (in the meantime PCB`d) protos for testing... :
        :icon_smile:    :icon_eek:    :icon_smile:
tca
#8
In a box!
and
Greenmachine
You're on fire Puretube!  I didn't know Sovtek manufactured amps ... cool.
JMV
Here's mine, the removable cover helps keep the dust out.
JMV
mg.audio
prototyping a two knob rat for bass...
asymmetrical clipping with blue LED's for the win!
Liquitone
Here's my breadboard. I've had it for over a year but only just started using it.
I couldn't get used to it really, but I guess it's something you need to get comfortable with to start using properly.
I improvised a connection panel for pots, in/outs pots and bypass switch from an old pedal enclosure.
I don't have the materials at the moment but when I do I'm going to make a better connection panel, like with a aluminium strip with holes for pot-meters and wiring strips, just to make things easier.
I can't believe I've put this off for so long, I never realized how use full this tool actually is.
To make things easier (its mostly getting lost in the maze of connections that does my head in), I built the different stages on IC-sockets where I soldered in the set connections, and plugged in the things I wanted to tinker with.
Now I can move around whole stages or add stages more easily.
Quote from: Liquitone on October 25, 2012, 03:10:01 AM
indeed, there are so many pedals i could have just built, and then would have been collecting dust on a shelf, and then eventually butchered for parts etc.......the breadboard is essential for trying out and tweaking circuits...
i don't build much, but when i do, its a keeper.... ;)
i must update my boards with that metal strip for pots idea too... 8)...i have in/out jacks/dc socket/3pdt toggle true bypass and led on my board.....and an EF mess too.. ;D
Resynthesis
That's neat!
Will.mendil
This post might be a bit old. But since I only started recently. Here's mine
I basically copied beavis audio'a layout
Don't know what to do with a paritculare transistor? Check this website where stompbox pedals are listed by what transistors they use
http://scfxguide.wordpress.com/
