Help me... Help you!
Started by Govmnt_Lacky, May 31, 2012, 12:09:06 PM
Govmnt_Lacky
I see that Univibes and lamp-based modulation effects are all the rage lately and I wanted to try to help out with the cause.
I have a metric crap-ton of small lamps here and I would like to help out some of the builders here with some lamps!  ;)
I tried researching the specs on what is needed for the lamps and I have gotten quite a few different numbers.
If a Univibe shadow master could point me to -OR- give me a range of specs for the lamps, I will pull from the stock that I have and share nicely with the other children  ;D
Pictures are always helpful... as are voltage and size preferences.
No guarantees that I will have 1000's of the CORRECT lamps. But, I figured I would try!!!!  :P
Cheers!  :D
Govmnt_Lacky
Wow...
Possible FREE Univibe bulbs and ZERO interest  ???  ???  ???
Oh well... at least I tried  ;D
Mike Burgundy
Weeellll, I'd like a few grain of wheat bulbs, problem is A) I didn't see the original post, and B) I'm not exactly next door ;P
