ProCo Rat massive volume drop
Started by markbee, June 06, 2012, 12:17:37 PM
markbee
Hi there. Ive just finished building ProCo Rat clone. I was following this layouts http://generalguitargadgets.com/projects/17-distortion/92-rodent.
Well it works but the volume drop is awful. I have Fender Champion 600 at home, i usualy play Low channel on 6 vol. When I switch the rat on,
the volume drops so much that i come close to the bypass volume only if i play on the High gain channel and all the pots are turned all the way up.
But its still quieter. Please help me, I have no idea which component might be causing it. Thank you.
Xavier
There is no secret solution. We have all been there many times....there's not a single pedal I have built that didn't need debugging.
Go to the debugging post in this forum and follow step by step. Check all voltages , solder joints, ground connections, and make an audio probe in case you still haven't one.
Don't panic and follow the circuit until you find where the error is. 100% of failures in my case were human :) .
Eric.nail
This is for sure my same issue! lol i was about to make a post on it but i saw yours instead. Any idea what it was? Let me know! i realize this post is old lol
I came, i saw, i taught little kids guitar for extorted prices.
ashcat_lt
Did you actually read the thread before you posted?  It's old, it's unresolved, and there still isn't enough information to even begin to help.  The one reply before yours explained what we need from you.
Eric.nail
I asked hoping to hear back from the person who has already dealt with the problem. Not some chump who think's he's smart. *&^*&^...
ashcat_lt
He hasn't been back since August.  You can help us help you, or...
StereoKills
The answer OP got is the same one you will get. Without any basic information about how the circuit is working (voltages, etc) there is no way to diagnose without taking shots in the dark. Your problem may very well have the same cause, or not!
http://www.diystompboxes.com/smfforum/index.php?topic=29816.0
This is the info you need to provide so others can help you!
"Sometimes it takes a thousand notes to make one sound"
