Help to recognise capacitors.
Started by scorpion73, June 07, 2012, 08:33:52 AM
scorpion73
Can anyone help me to recognise this capacitors?
Many thanks!
Govmnt_Lacky
Sure!
From Left to Right...
473 = 47nF or .047uF Ceramic disc
1 = 1pF Ceramic disc (looks like high voltage)
1nK63 = 1nF at 63V or .001uF at 63V Film box cap
10n 100 = 10nF at 100V or .01uF at 100V Film box cap
12 = 12pF Ceramic disc
Hope that helps  ;D
scorpion73
So they are not good for this project... http://db.tt/Nksuz6y6 . I have other two ones (1uf) that are correct, but i have to change those.. right?
the 1uf is an electrolytic capacitor,  these have a + and a -    positive/ negative
lke this..
http://www.rshelectronics.co.uk/product.php?id_product=323
C1 - 1μF  electrolytic
C2 - 0.01μF  =  10nf....use your 10nf
C3 - 0.001μF =  1nf...use your 1nf
C4 - 0.047μF =  47nf.....use your 473
C5 - 10pF  =   10pf....use your 12pf
C6 - 1μF  =   electrolytic
C7 - 0.001μF   1nf....use your 1nf
scorpion73
OK so i have 1uf right ones. But what of the photo capacitor i have to change for the project i linked?
scorpion73
Thank you! Very nice people in this forum ;-)
So i have to change my 1pf with another 1nf
CodeMonk
Jdansti
scorpion73
https://picasaweb.google.com/102217677074132084673/MxrDist here are my results!
I need more help! (I'm a noob xD) how can i recognise sleeve/ring/tip in this stereo jack:
And sleeve/tip in this:
Thanks as always !
tempus
I don't think you can. Plug a TRS phone plug into the jack, then take your meter, set it to the resistance setting, and touch one of the lugs with one probe, and touch either the tip, ring or sleeve with the other probe, until you find one that reads close to 0 ohms. That means that lug connects with that part of the plug. It's also extremely likely that the big lug (labeled 3) is the ground, or sleeve connector.
GGBB
#13
This might be a bit easier especially if you don't have a TRS cable handy.  Assuming #3 is sleeve (I can't imagine it wouldn't be, but I've been wrong before) just insert in a regular mono phone plug (tip+sleeve) and check for conductivity (resistance = 0) across the lugs, the one that is connected to #3 will be ring (and the one that isn't connected will be tip).
scorpion73
OK i tried what you suggest: when i connect 3-1 with the mono jack plugged the tester show 0.1ohm, and connecting 3-2 it shows nothing. So 1 might be the ring and 2 the tip.
scorpion73
Is there any evident soldering error that a noob as me can't see?
CodeMonk
Quote from: scorpion73 on June 09, 2012, 10:57:27 AM
Re-flow everything.
Especially the one above the 2nd zero in 2001, the one above that, and 3rd one from top, far right.
Just Re-flow everything :)
Jdansti
+1
Be sure you get the pads hot enough for the solder to flow onto them. I like using a flux pen on the pads and leads to get a nice even flow.  This is what I use : http://www.mgchemicals.com/products/835p.html
scorpion73
Ok thanks tomorrow i will do it. I hope for a better result :-)
Jdansti
Here's a great video on soldering technique:
