Help to recognise capacitors.
Started by scorpion73, June 07, 2012, 08:33:52 AM
Jdansti
One more thing-If you've never tried to remove an eight legged component, you could be in for a nasty time. The best way to remove the IC without damaging it is to use a vacuum tool that is designed to remove molten solder from each pad.
Here's an example:
http://www.amazon.com/gp/aw/d/B0002KRAAG
You might also want to invest in some IC sockets as Rob indicated.
scorpion73
YAY, IT WORKS!!!!  (cit.) I feel sooo good! Btw, c5 always had this blacklish mark :-)
Thanks to everyone! You are great!
Edit: i have a solder sucker ;-)
WHOOOOOHOOOOOOOO.....
Cool glad you got it going man...rock on!.  ;)
another happy bunny!...well done guys!. 8)
Jdansti
artifus
yay! well done - loving the enclosure!
