Anyone build the Jen Fuzz III as per the Dragonfly Vero Layouts?
Started by superferrite, June 08, 2012, 12:49:17 PM
superferrite
I found a chunk of vero just big enough for this puppy, and there is scant info on it and no youtubes.  Looks like a silicon tonebender with some clipping diodes.  That sounds like a LOT of fun!
Now THAT"S Italian!
Anyone do this one?  It looks like it might be a sweet mod platform.  A nice input cap blend, maybe put those diodes on a pot, etc...
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album18/album144/JEN_FUZZ_III_VERO_001.gif.html
http://www.aronnelson.com/gallery/main.php/v/DRAGONFLY-LAYOUTS_0/album146/FUZZ/JEN+FUZZ+GUTS.JPG.html
Psychedelic Garage Metal
superferrite
LucifersTrip
I usually build the first versions, so I built the "Jen Fuzz"
which is very similar to the "III".  It's actually closer to a Fuzz Face with an emitter follower up front and some clipping diodes.  It's a killer, loud, trebly fuzz with very good sustain. I don't think I modded anything...
I asked 2 times on this forum for ballpark voltages or even guesses for this or a similar circuit, and noone gave anything.
I can only give you a few tips. One, don't worry about the "odd" voltages for Q1. I still don't know if it's typical for an emitter follower/buffer, but I got this for e/b/c:
Q1 > 5.96, 6.12, 9.04
Two, don't use high gain transistors. I found that's probably the #1 biggest error when building vintage fuzzes. I blindly used 2N5088's as called for in the schematic, but wound up with ones with much lower gains (~200), which sounded far better.
Three, changing the diodes didn't have too much effect...though, I can't remember if I tried germanium.
In the end I got close to what jmusser described:
http://www.diystompboxes.com/smfforum/index.php?topic=43036.0
good luck
always think outside the box
joegagan
andrew's build lists a 220 instead of the 22 ohm on above schem. the 220 ohm makes a lot more sense to me.
interesting circ, regardless.  i always like to see early use of diodes to ground.
joegagan
based on past experience and j musser's build notes, i would try to make the thing more gnarlee by reducing the feedback 150k to 68k or so, and increasing cap size at input and between Q1 and Q2. possibly a larger cap to ground in place of the 22u. instead of a fuzzpot, possibly a pot between the diodes and ground would add to the versatility.
superferrite
Thanks guys!
Good suggestions, all.
John Lyons traded me for some transistors and now I have lots of low-gain silicon transistors for just such a project.  They're the key to lots of old tones, and you don't have all this piggyback BS to deal with!
LucifersTrip
Quote from: superferrite on June 09, 2012, 11:46:15 AM
you don't need low gains ones for these...just ones around 200 for Q1/Q2
http://transistor-spravochnik.ru/description/bc238b/23994
I should've noted that Q3 could be higher gain
http://transistor-spravochnik.ru/description/bc238c/23997
Just check your voltages...I got the best sound in the typical 4-5v range for Q3C
superferrite
kaycee
Built the 1st one, I think I used 2N3904's or maybe BC108's. Its loud, quite trebley with lots of sustain as noted- myself, I didn't like it much, found it harsh and unmusical and ebayed it on - its painted all black and stamped 'Stealth Fuzz' if anyone ever comes across it :icon_lol:
superferrite
I'll probably build it tomorrow or the next day.  I could always throw on a SWTC for a little bassiness.
Question:  Did the fuzz pot do anything, or was it just for show like a Shin-ei FY2?
LucifersTrip
Quote from: superferrite on June 10, 2012, 06:11:13 PM
the attack is the same as on a Fuzz Face...and fully works
??? not sure what you mean...the Fuzz pot in definitely not for show on both the silicon & germanium versions...
superferrite
Hmm, my FY2 does "really fuzzy" to "REALLY,REALLY fuzzy"
Not a bad thing, just an observation.
DougH
Quote from: LucifersTrip on June 09, 2012, 03:55:26 AM
good luck
The emitter follower voltages look pretty reasonable. Ve "follows" Vb and is roughly half of the supply voltage. Guitar pickup signal is a few hundred millivolts to a volt so the bias is not crucial.
Metal can 2n2222's sound good for vintage fuzzes. They have low hfe.
LucifersTrip
Quote from: DougH on June 11, 2012, 09:17:28 AM
at the time, what I thought was "odd" was that the voltages of the emitter and base were so close. I tried various gain transistors in that Q1 slot and the overall sound did change (not drastically)...and of course, the emitter & base voltages shifted up or down together, reamining almost the same as before.
