Footswitch replacement
Started by THOMMO, June 21, 2012, 08:53:47 PM
J0K3RX
Maybe wire it direct input/output without a switch to see if it works? That takes wrong switch wiring out of the equation... Then after you figure out the wiring add the switch back in.. Just a thought
Jdansti
Nyklus
+100
great idea(s)
yaya! it works now.
the bypass is sucha nice touch.
now i can reintroduce this pedal back into my chain.
you guys rock so much!
