Does anyone have a JEN double sound?!?
Started by tss, June 24, 2012, 05:16:45 PM
tss
I have one but the wiring is incorrect. If someone could post hi-res pictures of the wiring it would be fantastic. I have a couple of layout files (drawn) but they are incorrect. Thanks!
Paul Marossy
I built a clone of one, but it's just a circuit board sitting in a drawer now so pictures probably won't help.
However, I did do a PCB layout and it shows how the wiring should be. You can check it out here:
http://www.diyguitarist.com/PDF_Files/JenDoubleSoundV4.pdf
IIRC, it's a straight copy of the PCB that is in the original Double Sounds. Hope that helps...
tss
Hello Paul,
I have this file, but from whatever reason it does not work when wired this way. I don't know why... also my unit comes with a DPDT switch (seems original).
Paul Marossy
Quote from: tss on June 25, 2012, 02:14:14 AM
Hello Paul,
I was afraid you were going to tell me that. My layout is based on what info I was given by someone who had one. And I built mine from that layout and it worked. I remember I had a little trouble figuring out the switching part, but the layout I have here is what it ended up being. Maybe you can follow the progression of layouts here and see if you find anything that might help: http://www.diyguitarist.com/phpbb/viewtopic.php?t=522&start=0
This was made by the guy who had the Double Sound in his possession: http://www.franksmusic.homecall.co.uk/jen_doublesoundsuper/jen_doublesound_switches.gif
birt
#4
i have one that has been modified and i never tested it. but it's open right here in front of me. i'll compare it to that layout
edit: on mine the dist/wah switch has been replaced by a 5 pin din. and there's another 5 pin din. and a 9V in. and 2 extra pots...
i won't be much help here :p
http://www.last.fm/user/birt/
tss
I have figured it out!!! From whatever reason it wasn't as easy as I thought but now it works! I will post something showing my wiring!
Paul Marossy
Quote from: tss on June 26, 2012, 04:23:34 AM
Cool.  :icon_cool:
