EHX Stereo Memory Man with Hazarai
Started by karlfriedrich, June 28, 2012, 09:59:12 AM
karlfriedrich
Hello,
I'm new to this forum and I hope that I'm posting this in the right place.
I just bought a broken Memory Man with Hazarai and when I opened it up I noticed that someone clearly not a genius had cut the ribbon cable leading to the bypass switch and ripped the pcb from the switch and all that left is the broken switch with left over copper traces from the pcb and the cut cable. I'm going to wire a new switch straight to the main board but I can't be sure of how it should be connected from looking at pictures on the internet.
The following diagram shows how the traces on the back of the PCB go. But I can't be sure about the opposite site.
Can someone that owns the same effect please measure with a DMM the left over pins and post a diagram?
karlfriedrich
#2
This is how it looked when I opened it up.
karlfriedrich
A friend of mine did find me another pedal and I figured the wiring out. Here is the diagram and I have tested it and my pedal is working great.
