Joe Davission Overdrive/Distortions
Started by WGTP, August 13, 2012, 12:00:32 AM
Magnus
Hello,
I have build the negative-ground Obsidian-T with 2N5089's too
and this pedal really kicks ass - I have to box it next time  8)
Greetings
Magnus
AMZ Booster, Dist. +, DOD 250,
Dr. Boogey, Fuzz Face's, JCM800-Emu, LPB1,
May Booster, Obsidian, Orange T/B-Booster,
Pentaboost, Prof. Tweed, Rangemaster's,
SansAmp GT2, Superfly (Amp), Guv'nor,
Tone Bender MKI/MKII/MKIII, TS 808
WGTP
Stomping Out Sparks & Flames
DougH
Paul Marossy
I rebuilt the Amber Boost today. I like it with a simple tone control on it.
seedlings
#24
I'd been meaning to try the Vulcan and this thread was motivation.
I used 5088s instead of 5089s and it is thick and meaty. Since it's so easy to modify I:
- Removed the first voltage divider btw stage 2 and 3 and used one .01uF coupling cap
- between stage 2 and 3 I ended up with a .068uF coupling followed by 100k/220k divider
- 1uf bypass cap stage 1, and 4.7uF byp cap stage 2
- stage 3 removed byp cap, took output off 1k emitter through a 4.7uF
All this tapered off the lows a little more and brightened her up. I didn't use any 'bright' caps.  And that's where I like it.  Nice that it's so easy to modify! Thanks Joe.
CHAD
