Tech 21 VT Bass Background noise because of 4013?
Started by Luqqas, August 23, 2012, 11:15:58 PM
Luqqas
Hi there everybody,
My issue is next:
VT Bass (Tech 21) when is bypassed (and also when the effect is on) produces a background noise, irregular. Like bubbles sometimes. It's not hum or hiss noise. If a high gain signal is added, becomes more noisy
Is it possible that the 4013 switching method is in malfunction?
Could this IC be damage, introducing noise?
Regards!
Ok. This is it, definitely a passion.
Luqqas
For the record, I tried with diferent power sources: 9V Batery, switching power source and good, clean and homemada power supply. All quality stuff. And nothing, same issue.
R O Tiree
Electrolytic caps that are nearing the end of their useful life can make sounds similar to those you are hearing. It might be time to try replacing them?
...you fritter and waste the hours in an off-hand way...
Luqqas
I'll give a try to Electrolytics caps and replace it. Although the unity is not old. I mean, Character series is fairly new, don't?
R O Tiree
It could be a loose connection in the lead to the guitar? Or maybe the power supply?
Luqqas
