Installing 1/4" jack
Started by skern, September 01, 2012, 12:20:30 PM
skern
Hi all,
I've just installed a 1/4" mono jack in my EHX Freeze. The hole I drilled is a little off center, and so the tip connector (the long, bendy one) on the jack is touching the case (aluminum). Is this something to be worried about?
Sasha
pappasmurfsharem
I believe that would cause it to ground out on the enclosure. Could be bad
Kesh
it will ground your jack, effectively killing any signal.
as a kludge you could insulate that part of the box, and the back of the tip connector. i did this anyway on my first build as i didn't like all that metal looking like it might touch something.
trjones1
Like posted above, the jack touching the case will kill your signal.  An easy fix is to put a couple layers of electrical tape on the case to insulate that spot.
Pyr0
Drill the hole larger, then you should be able to move the jack away from the case a bit, the washer should cover up the extra gap from the bigger drill.
Seljer
Quote from: Pyr0 on September 01, 2012, 01:56:52 PM
Or get a circular file.
Or buy an enclosed plastic jack.
LucifersTrip
can't you rotate the jack so the tip is not hitting the case?
always think outside the box
QuoteI've just installed a 1/4" mono jack in my EHX Freeze.
Why?
Seljer
Quote from: garcho on September 02, 2012, 01:32:41 AM
Why?
I believe people have hacked in seperate wet/dry outputs so you can route the 'frozen' sound to its own amp/effects
skern
Why?
I'm modifying it so that I can hookup a piano sustain pedal to use in place of the footswitch.
