Problem with Echo Base feedback and level controls
Started by duck0872, September 02, 2012, 08:19:44 PM
duck0872
I just finished my echo base project, and I'm having problems with the feedback and level controls.  The feedback only gives 1 repeat until it's turned to about 90%, and then goes to 3 repeats until it's turned to maximum, where it goes to many repeats.  The level behaves the same way, it gives very little until turned to about 90%.  I've checked the wiring and it's right according to the layout.  Both pots are A100k in accordance with the build instructions.  Anyone have any ideas or have this problem themselves?
duck0872
At a quick glance i found 1 10k in a 47k spot.  I tested it and it's better, but not perfect, so there must still be some wrong parts. The modulation still isn't working, and when the feedback is turned up past 90% the repeats are getting louder and distorting.   I'm going to pull it out of the case tomorrow and go over every part to see what's going on.
