Geofex Spyder power supply question.
Started by digi2t, September 26, 2012, 11:42:50 AM
digi2t
Just need a reassurance insofar as the diode bridge is concerned.
I know that DB101 is spec'd, but I've got a line on DB104's real cheap. I know they're rated at 400V, but they should work just fine, right?
Cheers,
Dino
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
For diode bridges, more voltage rating = OK.
digi2t
#2
Quote from: R.G. on September 26, 2012, 12:57:31 PM
Thanks R.G.. Just came across an old post where you mention the DB104 as OK. Thanks again for the reply.  :icon_cool:
EDIT -  Just came across these transformers on Ebay. What's your though on these R.G.? Would they work?
http://www.ebay.ca/itm/60W-AC-110V-12V-Power-Converter-Low-Voltage-Lighting-Electronic-Transformer-/221087922567?pt=US_Lighting_Parts_and_Accessories&hash=item3379ddf987
Dead End FX
Maybe.
I tend to stay away from lighting-industry magnetics, because they're awfully casual about magnetic leakage. I really suggest the transformer that Weber sells:
https://taweber.powweb.com/store/pdlxfmr.gif
digi2t
Thanks for your advice R.G.
I finally went with the 41PG120, 115v Pri, 12v Sec, Sec. current 120mA.
I can get 16 of them delivered for under 70$. That, and all the other components + enclosure, will give me a clean 16 x 9vdc power supply for around 130$.
I can't get a Voodoo 8x for that, that's for sure!
Cheers,
Dino
Dead End FX
