Diode Compression Power Amp?
Started by blackcorvo, October 11, 2012, 02:14:35 PM
blackcorvo
I know there is a project for a power-amp using the diode-compression trick, but I wanted to know if you could use that in low-power amps (under 10w) to obtain the same effect?
I'm looking for a practice amp I can carry around easily, and maybe power it with a 12v 7.5Ah sealed battery.
She/They as of August 2021
Jdansti
It wouldn't be diode compression, but the Tiny Giant amp (20W) is a good one that runs on 12V. If you want under 10W, substitute a TDA2003 for the TDA7240A.
psychedelicfish
For a low powered battery amp, you could make this: http://sound.westhost.com/project113.htm, replacing the op amp with the diode compressor. As it says on the page, you could get 1.5W into 8 ohms, though probably less with a battery. You would probably have make a voltage divider across the battery, and use the middle of the divider as ground. If you want more power, you might be able to use a dc wall adapter to power it and replace the power transistors with some that have a bit more grunt.
If at first you don't succeed... use bigger transistors!
blackcorvo
Hey, I'm back on this subject yet again.
psychedelicfish, I was really looking for something with at least 5 watts, but that circuit seems interesting. Another one I found that is quite similar (but more powerful) is the following:
http://www.redcircuits.com/Page164.htm
However, a couple days ago I was looking at some old circuit boards I have in a box (which I use for recycling still-usable components), and in one of them there's a TEA2025 stereo power-amp, which gives around 2.5w per channel in stereo, and a little under 5w in mono (bridge). Also, it works from 3v up to 12v.
I haven't had much luck with chip power-amps in the past (they either distort horribly with a small signal, or they oscillate at full volume), but I might give this little guy a try. Seems simple enough, and I already prepared a layout in DIY Layout Creator (first layout I've done in a couple years, and I believe it looks decent):
http://img208.imageshack.us/img208/7305/5id.png
Still, I'm interested in trying the discrete op-amp + power transistors approach sometime in the future, specially because I could try using high-voltage transistors for the op-amp (MPSA92 for the PNPs and MPSA42 for the NPN), and I wouldn't have to worry about frying them anytime soon (and since these are low-gain ones, they might give a nice drive sound when pushed hard by a loud preamp).
blackcorvo
So, after looking around for discrete amplifiers that might suit this idea, I stumbled upon this sort of push-pull design:
Taking a good look at them, I decided to see if I could insert the Diode Compression Op-Amp somewhere in there and make it part of the power-amp.
So, after succesfully sticking the DCOA in there, and a lot of changing values of stuff over and over again, here's the result I ended up with:
ATTENTION! NOT TESTED!
I'm no engineer and I barely understand how to polarize a simple transistor booster, so I have no idea if this is even gonna work IRL. Most of the stuff I've built in Livewire worked in the breadboard afterwards, but you never know.
tca
Quote from: blackcorvo on October 11, 2012, 02:14:35 PM
I know there is a project for a power-amp using the diode-compression trick...
What trick is that? Which power amp?
blackcorvo
Quote from: tca on May 17, 2014, 05:32:21 PM
The trick I speak of is soft clipping as the power amp overdrives, and the project I was mentioning there is Joe Davisson's Diode Compression Amplifier. Only "problem" with that project is the power output (which is 100 watts IIRC) is way too much for me.
I play at home, just for fun, so anything in the range of 1w-5w would be ideal.
I know they have mentioned the Tiny Giant before, but I just really wanted to try getting a decent overdriven sound from the power amp.
Joe
I'm sorry to get to this so late.
The "diode-compression" power amp I posted worked but had biasing issues. So I'm using it without the diode tricks now. (Having run the amplifier in both modes, I came to realize that Bruce DePalma's design sounds *superb* as a guitar amp on it's own anyway.)
For smaller amps I think blackcorvo's concept seems doable, gonna play around with it in the coming weeks.
