DPDT Wiring - 2 effects and bypass with on-off-on?
Started by rudeez, October 17, 2012, 04:41:38 PM
rudeez
As the description says, i've done a attenuator but im stuck on the wiring of cab simulators.
I've done two cab simulators and need to be able to switch between those but also have a bypass. No led's needed.
So what i need is to be able to use two diffrent circuits and also have a bypass using a 3-way dpdt switch, is this possible and how would i wire?
ashcat_lt
Are these "cab simulator" circuits in series with the signal or in parallel?
If series, the most obvious ways to achieve what your shooting for are impossible with any type of DPDT.  Careful perusal of the specific circuits may allow some smartypants to find a tricksie way to make it happen.
If parallel (like these are actually just cap-to-ground filters) it's pretty easy.
J0K3RX
Quote from: rudeez on October 17, 2012, 04:41:38 PM
Yes, you can do it with 2 dpdt switches...
Processaurus
Does it have to be a toggle switch?  You cannot do it simply, only elaborately.  However it would be very simple with a 2P3T rotary switch.
