Understanding the PT2399 delay IC
Started by knutolai, October 22, 2012, 06:23:13 PM
knutolai
Hi everyone!
I recently stumbled by the Sewer Pipe Ring Verb thread here on the forum on got curious on fully understanding the PT2399. I thought it could be useful to make a thread devoted to questions and explaining of the chip as a lot of the pins are still half a mystery to me.  :icon_question:
So!
I've been over the datasheet (I've also been searching for other documentation without any luck) and the big mysteries to me are the pins 8 to 15. I have three main points I need help clarifying:
I:
Pin 16 "LPB1-IN" is the signal input pin Thats pretty obvious to me. I don't however understand why this is part of a low pass filter.
To rephrase:
What is the point of filtering the signal before it has been delayed? Also is LPB2 just a spare low pass filter left on the IC for our convenience?
II:
why is the delayed signal split and sent through a modulator and a demodulator separately? How does these to signals stand out from each other?
III:
In regards to the modulator and the demodulator: What is the application of the accompanying current controls CC0 and CC1?
If anyone know of articles explaining any of there questions please post them here!
The "delay" actually chops the signal into many time-slices.
If an audio signal frequency is more than half of the chopping rate, it will be "aliased" to an utterly different and usually annoying frequency. We normally filter-off such inputs.
Keywords for search--  nyquist, aliasing, sampling
Are we sure the _delayed_ signal goes to "DEM"? Or is this just a case of twisting the drawing to fit the pin-out?
Looking at the schmitt-trigger near the input, I would assume a Delta-sigma technique for analog-digital conversion.
knutolai
CynicalMan:
That's certainly a more detailed schematic than the one I found in the datasheet! Thanks a lot!
LPF1:
Removes frequencies higher than the samplig frequency divided by two. That is the sampling frequency of the AD-coverter. Thanks PPR you are allways very helpful!!
MOD/DEM:
On both the datasheets I've looked at the digital delay is sent to both DEM and MOD. I found this (http://en.wikipedia.org/wiki/Delta_modulation) article which pretty much explaines the matter of there being a MOD, a DEM and their acompanying opamps. (I'll be doing my research more thoroughly next time)  :icon_redface:
These components form a DA-converter.
Now about the CC0 and CC1 I found this in another thread:
"I've been told by the manufacturers (and there's no other way to find this out) that pins 7 and 8 are used to smooth the a biasing supply inside the modulator (MOD) and demodulator (DEM) blocks.  There's no reason to mess with these pins, or the caps on it.  (Initially I thought this was part of the ADM slope control but it's not)."
-Rob Strand
http://www.diystompboxes.com/smfforum/index.php?topic=29859.0
> article which pretty much explains the matter
Good. (Because although I know the words, I could not build or explain a delta-mod system.)
