PT-80 delay problems
Started by FuzzFace_EXP, November 05, 2012, 06:29:36 PM
FuzzFace_EXP
So this is my second go at this pedal the first was a total faliure. This one is working but with some problems. At first i had the pots wired backwards fixted that but still have some issues. When the delay is on and i strum the sound of the guitar sounds gated and with some distortion. The repeats have to be all the way down or it becomes uncontrollable the delay time set all the way down still sounds pretty fast, the level pot does its work just fine. Im using a 18vdc power supply. Here are some voltages i got.
PT2399
P1 - 4.96V
P2 - 2.49V
P3 - 0.01V
P4 - 0.01V
P5 - 2.77V
P6 - 2.48V
P7 - 3.80V
P8 - 2.26V
P9 - 2.49V
P10 - 2.40V
P11 - 2.50V
P12 - 2.49V
P13 - 2.48V
P14 - 2.49V
P15 - 2.49V
P16 - 2.49V
NE571
P1 - 0.97V
P2 - 1.83V
P3 - 1.83V
P4 - 0.00V
P5 - 1.83V
P6 - 6.69V
P7 - 6.69V
P8 - 1.83V
P9 - 0.97V
P10 - 1.83V
P11 - 1.83V
P12 - 11.96V
P13 - 1.83V
P14 - 1.83V
P15 - 6.33V
P16 - 1.83V
TL072
P1 - 6.00V
P2 - 6.00V
P3 - 6.00V
P4 - 0.00V
P5 - 11.96V
P6 - 5.99V
P7 - 5.99V
P8 - 5.46V
78L05 - IN 17.97V OUT 4.96V
78L12 - IN 17.96V OUT 11.96V
FuzzFace_EXP
I've been looking at the board and found a pad that was burnt do over heating. I got that fixed its working a bit better but still the delay time at its lowest setting is still to fast. I re checked the wire and it seems just fine. The repeats pot is still a little wierd its uncontrollable.
