These Phaser's work?
Started by Crontox102098, November 06, 2012, 06:08:03 PM
Crontox102098
I have for quite some time researching the phasers to see if I can find one that does not need the FET's despicable that do not sell in my country. :icon_cry:
I found these two schemes on page 'experimentalistsanonymous.com' which incidentally is buenisima to find cool effects, back to the topic I found these schematics such Phasers:
In this case I think this is a phaser of 2 Stages but you can add up to 12 (I think) and would like to know if this replacing the 22K potentiometer for LDR and placing a LFO will the Phaser effect, but ... I mainly want to know if it is the same as feeding it with 9V will work?
For the other it is a different case, is more explanatory and tells us that we can place a LDR and 12 Stages (which I love to do) my question is this, if you put another stage and mix at the end (as seen in the first diagram) will work?
I would greatly appreciate if you help me with this question, I'm in college and I want to impress my teacher with this effect, in addition to share with others and make one for my course :3  :icon_mrgreen:
I'm Carlos.
I speak spanish, just in case you do not understand what I say.
What country ?  We have over 25000 members around the world.
Crontox102098
Quote from: Mark Hammer on November 06, 2012, 06:32:24 PM
In my inforcacion appears, is Colombia.
I'm Carlos.
There may be some other members in Colombia, or somewhere else that is near, who can provide you with FETs.  I know that Small Bear Electronics provides parts to members all around the world.
You can also make a phaser using transconductance amplifiers (the LM13600 and LM13700 chip), or photocells.  Can you buy those where you live?
Crontox102098
Quote from: Mark Hammer on November 06, 2012, 06:55:35 PM
I live in Santa Marta, Magdalena, Colombia.
I knew what the transconductance amplifiers, but can not find them here either, so would like to know where to place the photocell to see if any of the two phasers works ... but mainly want to know .. these two phasers to place beyond work?
I'm Carlos.
Crontox102098
Please,  :-\ I need help with this... :icon_neutral:
I'm Carlos.
Jdansti
The diystompboxes store has 10 JFETS for $3.50US. You would have to see if he ships to Colombia. If he does, he could probably ship them to you for $3-$5US.
Nasse
 ??? that upper circuit does not need ldrs
That 22k potentiometer in the upper circuit is just depth control, and voltage divider, lfo is connected to that 0-12 volts line
It might work good enough at 9 volts, those 100k resistors control the current for diodes used as voltage controlled resistors, you may try other value than 100k.
100n caps take audio to ground from that upper diode to cancel some distortion
original article said benefits were good matching of stages, no need to select diodes, some of drawbacks is low headroom and distortion
Crontox102098
#8
Quote from: Jdansti on November 06, 2012, 10:04:44 PM
In my country i'm a adolescent, i have 17 years old, i cant have a credit card and my parents have but do not trust online shopping. (I write without the traductor... I LEARNING :D )
Quote from: Nasse on November 06, 2012, 10:19:52 PM
I did not understand very well but I just have one question ... like them to change the speed of the phaser?
And you have the article original?, please pass me?
I'm Carlos.
Jdansti
Send me your home address in a personal message and I'll mail you some JFETs.
StephenGiles
I'm sure that Chavez and Kirshner have a stash of FETs!
