led indicator in a rangemaster clone running off -9v and ground, can it be done?
Started by njkmonty, November 09, 2012, 05:18:29 AM
njkmonty
i have made an external power thingy in a 1590b enclosure with a LT1054
it does the usual , provide  9v +   , 18v + , and 9v-
just wondering if a led would work using -9v ?
or do i need to build the charge pump circuit/voltage inverter, into the rangemaster, and use the 9v+ for running the led?
ie my rangemaster works with the -9v, but no way visually to tell when on or off?
You do it the same as for running on +9 volts, you just have to reverse the connections to the LED.
So -9 volts >>> resistor >>> LED cathode LED anode >>> To stomp switch
Kesh
voltage is always relative to some other voltage
so between +9V and 0 is the same as between 0 and -9V
connection should go
0 => +LED terminal, -LED terminal => -9V
WITH A RESISTOR IN SOMEWHERE, and whatever switching you use, as normal.
