Vintage Fender Reverb
Started by KazooMan, November 11, 2012, 05:42:00 PM
KazooMan
In another thread about the Belton Brick I said I would be happy to post information on the original Fender Reverb.
I have a 1965 Fender Reverb.  Here are some gut shots and the layout.  The actual schematic is available but the manual for the reissue is what you should go for.  I have a pdf, but don't really know how to post it here.  I can send it to anyone who cannot find it online.
External dimensions:  19"W x 7 1/2" D x 10 1/4" H
The front grill cloth is set back 1/2" from the edge of the cabinet.  The cabinet is made from 3/4" stock and has 1/2" rounded edges.
The chassis is 15 1/2" L x 4 1/8" W x 2 5/8" D.
Greenmachine
Cool.  Thank you for those great pics.
Mustachio
Awesome! I played on one of these when I was younger and loved it! Was dreaming about building one some day. Thanks for the pics and schematic! gonna add it to the list!
"Hhhhhhhnnnnnnnnnnnnngggggggg"
KazooMan
This is actually a very simple build (if you are comfortable with line voltage gear).  The big ticket items are the PT, choke, and reverb pan.  Still, I think it is well worth the cost and effort.  There has never been a digital reverb that sounds like a good spring unit.
Building a box to hold it is pretty simple.  You can get as detailed, or NOT as you want.
The chassis was a problem for me when I built a clone.  I had no resources for bending steel in a brake.  I ended up using aluminum angles (~2" X 2") and capping the ends with more pieces of angle.  It worked fine, but I think I may revisit this one.
For the STOMPBOX purists, the circuit calls for an external ON/OFF switch, so you can stomp to your heart's content.
Barring a huge studio plate reverb (I have actually looked into building one) this IS the real reverb.
