Once you have added files, rebuild the Quick Find menu.
Rebuild the Quick Find Menu
Choose Quick Find
Press Rebuild
Press rebuild and wait a few seconds for the menu to be rebuilt. This will scan and sort the Quick Find list.
unrealBook Mobile provides simple access to dropbox for downloading files.. Note: you must already have a Dropbox account at dropbox.com
Sign in to Dropbox
Sign into dropbox using your email and password. Once you are signed in, choose Dropbox again.
Once you are into the Dropbox Home folder, use the buttons on the bottom to download, get new files or sort.
Select a file and use the Download button to download the file to unrealBook mobile. Press Get New to get newer versions of file and files that don’t exist in unrealBook mobile. Press the Sort button to sort by name or by date.
Once a file has been displayed, use taps and swipes to operate unrealBook Mobile
Tap on the left or right of the page to change pages
Tap on the left or the right to turn pages.
Swipe left or right to turn pages as well
Left or right swipes will turn pages.
Use 2 fingers to zoom in and out. Double-tap center of screen to reset zoom
Note that you can only turn pages when the screen is not zoomed. (Double-tap center of screen to reset zoom).
Swipe upwards with 2 fingers to exit and return to Quick Find or tap left top corner.
Swipe upwards with 2 fingers to exit current file and return to Quick Find or tap the top left corner.
Tap top right corner to access side menu in portrait orientation.
You can add the current song to a set list or create a bookmark using the side menu.
Using the side menu in portrait orientation
usingOperat
SL+ will allow you to add the current song to a set list. B+ will allow you to create a bookmark to the current file and page.
