Creating PDF from lyrics
Provides a quick way to paste in lyrics from a website and create a quick PDF. Any text pasted into the lyrics window will be saved as a PDF file.
Using Create Lyrics
Go to a lyric website and copy the lyrics. Then choose Create Lyrics in unrealBook Mobile and paste the lyric text into the window. Press Hide Keyboard to dismiss the onscreen keyboard. Press Save to save the lyrics as a PDF file. Pressing Settings will allow you to change lyric fonts and sizes. Upper will make all lyrics upper case. s, L control the text size (small and large). 0 is the original font from older versions of unrealBook. New will allow you to reset the document starting from the beginning. Press Existing to edit an existing lyric file.
