In search of a capacitor...UK based
Started by dmk, November 01, 2006, 03:10:11 PM
dmk
Does anyone know where i can get a 0.68uf 63v cap from in the uk? i know its from the E6 series so its going to be less common, but i cant seem to find one anywhere.
cheers
resistance is futile...
...if <1Ω
Ge_Whiz
P/N 10-3270 from Rapid Electronics www.rapidonline.com, 24p each. Bit expensive to buy just one, though.
what's it for? You might be able to get away with another value. Or just stick a 0.47uF in parallel with a 0.22uF, that's possibly close enough.
dmk
thanks for the replies.
24p is a bit pricey. its the £3.45 postage thats the killer  ;)
the part is for a marshall 6100lm head. i'm changing the lead channel back to non lm spec. basically less gain, less compressed.
i'd probably get away with a 0.47uf and 0.22uf in parallel. i never thought of that.
cheers again
...if <1Ω
MASTER VOLUME
Hi, how about trying //www.ampmaker.com . They sell everything for building and moding amps.They don't charge a lot for postage, probably under £1 for small components.
