Can someone enlighten me?
Started by neon333, July 14, 2005, 08:25:12 PM
neon333
I pulled this down from Justin Philpott's site.  Why does he suggest replacing the 0 ohm resistor with a jumper and what about the note in red about the diode?  I'm fine with the DPDT stuff.  Those other notes have me scratchin' my head.
url:    http://scoot.net/gallery/bbs/crybaby95.gif//
Toast is from the Devil.  It's burned Devil bread.
jra2217
Quote from: neon333I pulled this down from Justin Philpott's site.  Why does he suggest replacing the 0 ohm resistor with a jumper and what about the note in red about the diode?  I'm fine with the DPDT stuff.  Those other notes have me scratchin' my head.
url:%20%20%20%20http://scoot.net/gallery/bbs/crybaby95.gif
ther you go.
neon333
sir_modulus
The diode is for polarity protection I assume? So any diode that has the same rating (as in a 9.1V zener diode) can be used. used to be on all stock crybabies. As for the resistor, just saying that the original comes with a zero-ohm resistor, but you can use a jumper instead.
Cheers,
Nish
