Help! Beginner Enclosure Problems
Started by Sonicxyouth, November 12, 2015, 02:16:52 PM
Sonicxyouth
I have build my own overdrive using the PG Distortion guide and the kit from Mammoth Electronics. I used the included perf board even though it was much bigger than the one shown in the instructions. This proved to be a terrible choice because now it won't fit inside the enclosure. I have since cut the perf board and am proceeding to flip it over but I really can't seem to get the back screwed on the enclosure and it shorts out the circuit when I try to. I'm tempted to just wrap the whole thing in electrical tape or something. Please help with any tips you use to get a circuit board in a tight fit enclosure. Thanks!
bloxstompboxes
First off, welcome to the site.
Second, pics and perhaps a link to the project would be helpful. What type of enclosure is it, what parts were used, etc? The more info you can give us, the better we can help.
Sonicxyouth
Thanks a lot! I am not quite over the learning curve of attaching pictures to this forum but I will work on getting there. This is the exact link to the kit I bought
http://www.mammothelectronics.com/PG-Distortion-Pedal-Kit-p/kit-tnfnd-dist.htm
Its slightly larger than MXR sized if that helps at all. For the circuit itself, I used an 2N3904 transistor, a few resistors, one 104 cap, one 683 cap, a 22 uf electrolytic cap.  I used a 5mm LED, a 1N4001 silicon diode, and a germanium diode to promote asymmetrical clipping. The overall goal with this pedal was to create an overdrive pedal that sounds nothing like the TS9 Tubescreamer. Which is why I am calling this pedal (if I can ever get it working) the No Clone. The 22 uf electrolytic cap and the 5mm LED are giving me trouble because their height is greater I will keep trying for pictures. Thanks again for the reply!
bloxstompboxes
While the values you gave are important in deducing the actual size of a cap, the voltage rating will as well. A high voltage rated cap will be larger physically than a lower voltage cap of the same capacitance value. After clicking the link, I can see that, as long as the components in the picture are the ones used and the drilling was right, I don't think there would be an issue in fitting it all together. We need a picture.
Sonicxyouth
#4
Finally got it! Woohoo! Okay, so here is a photo of my initial problem. This is as far as the board would go into the enclosure and once I had the back plate  on, it would short out the circuit.
Sonicxyouth
#5
Here is a picture of what it looks like now. I have flipped the perf board over in hopes it will fit in the enclosure better but its not looking to good.
Cozybuilder
#6
For posting photos, first transfer your photo to a web-hosted address, such as Photobucket or Imgur. Once there, click on the photo, it will give some options, select the "Direct" one. This will copy the HTTP:/ address.
In your post, select the binoculars icon, it will give this:
"{img}{/img}", but with square brackets.
Place your cursor between the square bracket pairs, select "edit", and select "paste". Check preview- much too big, right? OK, in the left parenthesis [img]http://, size it as follows:
[img width=500]
you can play with the number to wind up with the image size you want. Check by selecting Preview below right, before posting.
Cozybuilder
Sonicxyouth
Thank you so much for the image attachment walk through!
My question is how do you guys get a circuit board in a tight fit enclosure? Any tips on such a quest? In hindsight, I will build in mind with realizing that I actually have to fit it inside the enclosure (duh) so that should prevent this problem in the future.
Sonicxyouth
This is my schematic I am going off of with the exception of adding one more diode and the value of C1 being a smaller 683.
SuzukiScottie
You would have been better to trim the circuit board down to a much smaller size. You could make half a dozen more circuits from the free space on that board.
Sonicxyouth
You're right but this was my first build and I never thought about that until after the problem had occurred. Hindsight is always 20/20 or something like that.
you may be better off just rebuilding the pcb.
only much much smaller...have you any veroboard/stripboard?..
or just cut that board down
sometimes going backwards a step takes you forward 3.. ;)
the 4.7k/led looks like its really for the switch...so leave that off for now...
keep the electro cap (100uf) though...
Cozybuilder
My method is to fit the hard components to the box first, including the blank perf with some way of attaching it solidly to the box, then I have a good basis to work out a wiring diagram, keeping in mind where the tall components have to sit to avoid contacting the hard bits in the box. Your circuit can take up a remarkably small amount of perf, so you have a lot of options.
Sonicxyouth
I really like the sound the 5MM LED provides. I have 3MM LED too...would that sound the same? And yeah I suspected I might have to rebuild the whole perf board.
Sigh.
Cozybuilder
View this as just another chapter in the education process, not redoing something, it takes the sting out.
Sonicxyouth
I just keep telling myself that one day I'll be good at this hopefully! Thanks for the help, you guys are great
smallbearelec
Hi--
If you look in Projects on this forum, there are two articles of mine that will help you:
http://www.diystompboxes.com/beginnerboost/
http://diystompboxes.com/beginnerboostbreadboardtobox/BeginnerBoost.htm
The first one covers the use of a solderless breadboard. You have actually made a circuit work as a soldered build, so maybe you are past that, but it still might be good to look at. The second piece is a look at building a pedal in a systematic way and some techniques for getting a good result.
The learning curve to building good pedals involves building several different skills, not necessarily all at once or always in the same order. I hope you'll back up a little and build something from a vetted design that someone else has worked out. For a look at a complete build that is similar to the circuit you are working on:
http://diy.smallbearelec.com/HowTos/BreadboardUrsaMinor/BreadboardUrsaMinor.htm
http://diy.smallbearelec.com/Projects/UrsaMinor/UrsaMinor.htm
Regards
SD
Sonicxyouth
Quote from: smallbearelec on November 23, 2015, 10:34:18 AM
Hi--
Regards
SD
Hi! Thanks so much for the reply, very helpful stuff in what you've mentioned. I think now I'm actually going to rebuy all the parts and build the same pedal again because it didn't turn out exactly how I wanted it to quality wise. This run should be way easier though because now I know what to do! After I do that, I'll look into what you've mentioned.
Hatredman
Quote from: Sonicxyouth on November 28, 2015, 09:16:27 AM
Why buy everything again?
In fact, learning to securely desolder components and stripping them out of the PCB is a skill you'll have to learn someday, so why not now?
Kirk Hammet invented the Burst Box.
