Wiring in a DC jack
Started by Easywider, April 28, 2007, 04:43:54 PM
Easywider
Using the GGG layout for Octavia ,  attached url to wiring diagram which shows no DC jack , how would i do this , Thanks !  //http://www.generalguitargadgets.com/index.php?option=content&task=view&id=49&Itemid=88
burnt fingers
Rock and Roll does not take a vacation!!
www.rockguitarlife.com
My Music
Easywider
Thanks ! Just looked at the diagram , shows one wire going to the board grounds , don't know where to put that wire on the board , please help !
GibsonGM
Hi Easy,
Just run the ground wire to any ground point on the board...if you're using a pre-made PCB, you can run it behind and solder it on the back (copper side) where a component grounds out.
Alternately, you can connect it to the ground point on your input jack - but that's usually on the other side of the enclosure from where the DC jack goes...not great to have long runs.  I'd go to the board....
8)
Easywider
#4
Thanks , all jacks , including the dc jack are front mounted on the enclosure , like JD mounts them , so I could run ground to the input jack easily , run the wire to the Sleeve lug or the Ring of the input jack , unsure ? then run the positive side of the dc jack to the 9V+ on the board , right ?
Easywider
#5
the ground on the input jack is the sleeve or the ring , unsure ? then run the positive side of the dc jack to the 9V+ on the board , right ?
